9/16/2010 4:46 PM | |
Posts: 8 Rating:
hello Denilson ... I write to you from South Africa ... Johannesburg ... I have found and downloaded your program - for ... serial.zip .... and also ... HyperTerminalReceive_RS232 ... I am surprised at how simple it really is.... I am sure though that you need to use the other faculties of the PtP system, for serial..???? yes..??? - or NO..??? Unfortunately - I do not have the serial port for my 1212C - S7-1200..... but nevertheless - it is good to try to learn something newer everyday...!!!!!! What I would like you to explain to me... is.... 1) - how did you enter, the Test word into the Data_block_1 - for input BUFFER ... how do you create that file...??? please...?? can you explain to me simply - how that is done.. (I am very very new to PLC of S7-1200 .... and would like to learn as much as possible - as soon as possible..)... [schnippschnapp] second question is transferred to Counters in Step7 Basic. Denilson - I thank you very much - you are an inspiration.... to me... My Kindest Regards Spencer Sabatta Johannesburg South Africa.. Splitted from Sample program S7-1200 RS 232 ASCII HypterTerminal comunications. |
Last edited by: O_Moderator at: 9/21/2010 2:21 PMnew subject after splitting Last edited by: O_Moderator at: 9/20/2010 12:33 PM |
