5/21/2013 11:26 AM | |
Joined: 10/9/2007 Last visit: 2/4/2025 Posts: 1253 Rating:
Hi Sicam and Toolbox are not products from A&D,but fromEnergy Automation. There are some colleagues here which know the products, so you can get some information. Please contact your local Siemens partner or energy.support@siemens.com |
Energy Automation products: Sicam, Siprotec, Digsi |
5/21/2013 11:47 AM | |
Posts: 8 Rating:
Hi Mike J, Thanks for your kind reply, yes i think you right, just if you don't mind. seemsthis case same if ask how to export to SICAM SCC? because i'm using SICAM SCC also in my system network,I can use two solution import to SICAM PAS or directly to SICAM SCC. but theproblem i don't know yet both this solution. thanks. |
5/21/2013 11:55 AM | |
Hi I don't know toolbox |
5/23/2013 1:34 PM | |
Posts: 12 Rating:
Hello,I worked with Toolbox II a little bit. I think, you have to open OPM II and chooseTarget systems - > SICAM PAS |
5/13/2014 7:48 AM | |
Posts: 340 Rating:
new question is splittet to how can i export the xml file from tim to the pas, (sicam pas and hmi pas cc). |
