11/7/2014 4:57 AM | |
Posts: 122 Rating:
Hello Experts, I would like to have the information or know how to find the absolute address of the variables in the Data Block. It was available in Step 7 5.5 . Is it possible to find in TIA portal V13 too?. Looking forward to hear your response. Here with I attach you a snap shot with regard to my question. With regards Johannes
AttachmentZipFile.zip (750 Downloads) |
11/7/2014 5:30 AM | |
Joined: 1/28/2009 Last visit: 2/8/2023 Posts: 6788 Rating:
Hello Johannes4u, The reason may come from "Optimized block access", To be able to have access to absolute addresses you have to disable this option for each block as you like in properties of a DB(Right click on DB-->Properties-->attribute--> Optimied block access.Read more in the following link from STEP 7 Professional V13 manual(also read the restrictions and special features):
Setting up block access
What differences should you watch out for between optimized data storage and the standard type of block access in STEP 7 (TIA Portal) V12? I hope this helps, Hamid Hosseini |
5 thankful Users |
11/7/2014 9:26 AM | |
Posts: 122 Rating:
Thank you hdhosseini, It was informative. With regards Johannes
