12/12/2012 9:32 PM | |
Joined: 7/7/2010 Last visit: 12/6/2023 Posts: 13982 Rating:
I wish I could answer that question. Contact Support Requestand let them know your concern. I also have to contact them if I am unable to figure out which LADDR object to choose. From everything I've found, it is pure guess-work unless you understand the system much better than I do. Luckily there are only so many of these, and if you must guess, you can insert the logic to run it for every choice you think could provide the results, and once your block returns results, you can disable the others, move the results for further processing/handling/logging/etc. and retain that setting. If enough people note the complete lack of documentation on this by contacting support, maybe they will make the drop-down easier to use, documentation make more sense, and in general explain these parameters in layman's terms. |
science guy |
