5/19/2008 6:23 PM | |
Joined: 3/22/2008 Last visit: 6/14/2021 Posts: 63 Rating:
Help! |
5/19/2008 6:51 PM | |
Joined: 9/27/2006 Last visit: 9/21/2023 Posts: 12152 Rating:
Hello Torpedo; The following FAQ contains a downloadable library for WinCC Flexible 2005 for an Audit Traiol add-on. It mentions links with 21 CFR part 11 and GAMP. It is designed to run either on a MP370 or WinCC Flexible RT. http://support.automation.siemens.com/WW/view/en/24327008 Hope this helps, Daniel Chartier |
5/21/2008 1:23 PM | |
Joined: 5/8/2006 Last visit: 2/22/2023 Posts: 1085 Rating:
Hi, maybe this FAQ will help you (chapter 2): http://support.automation.siemens.com/WW/view/de/18657078/0/en Bye |
1/14/2020 9:28 AM | |
Joined: 4/28/2015 Last visit: 5/24/2023 Posts: 1 Rating:
hi, this link doesn't work. Has the entry been removed ? Thanks |
1/14/2020 1:15 PM | |
Hello; The original link was 12 years old, and referred to hardware and software that is mostly out of date. So that link has probably been removed form the site. An alternative entry might provide information for your search on 21 CFR part 11 implementation: https://support.industry.siemens.com/cs/us/en/view/37939948 Hope this helps, |
