4/27/2020 8:56 PM | |
Joined: 8/3/2017 Last visit: 5/12/2022 Posts: 12 Rating:
Hi, I have a unit that I'm trying to load and OS Image but I don't know how to get into the BIOS to enable the Boot from USB function. I've tried ESC, Delete, and F!, F2, F8 and F10 already? Please let me know... ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/28/2020 10:25:58New subject after splitting |
4/28/2020 10:53 AM | |
Joined: 4/28/2015 Last visit: 12/1/2023 Posts: 3294 Rating:
Hi, which device do you have and which OS you want to install? Best regards! |
4/29/2020 5:21 PM | |
I have the quad core unit, the lightest Debian 10 I'm assuming unless you have a better recommendation? |
4/30/2020 8:27 AM | |
Hi, this must be a prototype. And the quadcore devices have an example image preinstalled at the eMMc. You can only use this example image or the SIMATIC Industrial OS at a later stage. I wasn't successful installing another OS. For changing the boot order you have two options:
Best regards! |
5/7/2020 7:18 PM | |
Joined: 12/4/2019 Last visit: 1/11/2022 Posts: 2 Rating:
Where can you download copies of the Debian OS for IOT2050 dual core and quad core? |
5/27/2020 6:24 PM | |
Is there a recommend procedure with using the TTL cable? |
