12/13/2024 8:44 AM | |
Joined: 8/3/2009 Last visit: 2/12/2025 Posts: 14745 Rating:
Hello g.locatelli If you are not sure what is going wrong in your script then you can use Trace outputs and check for errors int the RTIL trace viewer or also use the Debugger in Chrome for an easy troubleshooting: https://support.industry.siemens.com/cs/de/en/view/109777593 Bye Murof |
