9/16/2013 11:20 AM | |
Joined: 4/22/2010 Last visit: 2/26/2025 Posts: 5697 Rating:
Hello, First you have to set your PG-PC interface to the correct interface to connect to your CPU Then follow the attached Pdf. Note thatin your uploaded program there are no symbols, variable names and comments. Succes, Regards, Marcjan Attachmentupload.pdf (65 Downloads) |
Problem solved? |
