8/29/2021 8:02 AM | |
Joined: 5/12/2018 Last visit: 8/3/2023 Posts: 3 Rating:
It can work successfully on other device I asked for the kernel header from SIEMENS, but it may not correct? I searched it on websit, if it is in OpenSourceSoftware.zip (1,8 GB) ? |
8/30/2021 7:55 AM | |
Joined: 4/28/2015 Last visit: 9/21/2023 Posts: 3256 Rating:
Hi, they can't be downloaded, you would need to build the kernel headers on your own. There is discussion about that in this issue on github. Without compiling the driver the stick is not recognized as wifi0? I have read on some other forum that you also can install the dkms package or try to install linux-firmware |
8/31/2021 8:27 AM | |
Thank you. I have a try. |
