6/19/2015 2:41 PM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15318 Rating:
Hello dan.v. Its not possible to log Strings in a direct way. You can use a workaround like in the following FAQ: https://support.industry.siemens.com/cs/ww/en/view/28626979 Its a WinCC flexible FAQ but its quite the same in TIA portal. Hope it helps Bye Murof |
Last edited by: Murof at: 6/19/2015 2:43:01 PMIf this Information really helps, you could use the Rate function |
