9/30/2024 11:18 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Siyab you can use the GmsgFunction -> it is executed every time an alarm comes up. in winCC V7/8 it is described but it works also in WinCC Prof similar. here is a lin to a discussion of a similar topic: https://support.industry.siemens.com/forum/de/en/posts/gmsgfunction/190598 I hope this helps Bye Murof |
