11/12/2019 12:14 PM | |
Joined: 9/27/2006 Last visit: 4/19/2025 Posts: 12346 Rating:
Hello JKV_JAMES; The definitive answer to your question is found in the following document: Which languages are available in WinCC TIA Portal (Basic, Comfort, Advanced)? https://support.industry.siemens.com/cs/ww/en/view/83630011 Unfortunately, the language document contains this warning: "Note The following discussion offers a workaround for an older panel from Hiatis, see if it works with your version of TIA Portal and your display: Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 11/12/2019 12:21:54Last edited by: dchartier at: 11/12/2019 13:02:22 |
