11/15/2023 7:19 PM | |
Joined: 1/21/2013 Last visit: 2/12/2025 Posts: 3540 Rating:
Hi Thenameinforum, The transparency of a graphic in WinCC Unified is not the same as in WinCC Comfort/Advanced. While in WinCC Comfort/Advanced you can select a color that is to be displayed as transparent, in WinCC Unified you need a graphic that already contains transparency settings. For WinCC Unified, the file type of the graphic is important. From the list of supported graphic types, *.ico, *.gif, *.tif, *.png and *,.svg should support transparency. Kind regards |
