5/12/2019 12:20 PM | |
Joined: 5/21/2017 Last visit: 5/20/2019 Posts: 11 Rating:
I know the question may sound basic but I actually cannot get the screen sizing to change. Kindly help |
5/13/2019 12:54 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Ann10 I also cannot imagine whats the problem? DO you see something different on the Panel after loading and on the Screens in the Engineering? Which TIA Portal Version do you use? Check also the DPI Settings, perhaps it has something to do with your problem: https://support.industry.siemens.com/cs/ww/en/view/13899072 Bye Murof |
