6/24/2013 4:08 PM | |
Posts: 559 Rating:
Dear abhi07, This should not be happen, if you make False at EN_R then your block should not receive any data. But still if you are getiing then please check for another call for the same block also. In this case you just stop the calling of block by giving NO contact at EN then see the result. Please reply once you check it. |
6/24/2013 4:58 PM | |
Posts: 3093 Rating:
Hello Abhi07, just take the CP340 manual and take a look at section 6.6 FB12 P_RESET. The input EN_R of P_RCV blocks the data transfer from CP to CPU. It can't "switch off" the USART. Regards, Kaulquappe |
