12/9/2011 9:58 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, See attached Lad diagram, it's written in Microwin, but you can use it in any PLC. Regards, Marcjan Attachmenttoggle.pdf (6513 Downloads) |
Problem solved? |
11 thankful Users |
12/9/2011 1:24 PM | |
Joined: 9/8/2009 Last visit: 7/17/2023 Posts: 1410 Rating:
Thank you for this nice trick, Marcjan |
12/9/2011 1:40 PM | |
Joined: 3/21/2006 Last visit: 12/4/2023 Posts: 10222 Rating:
AIO (All in One) how to use only one push button to on/off the output (the fastest is a winner) |
12/9/2011 1:42 PM | |
Hello, You're welcome. Version in TIA attached, note the extra flag you need for the edge evaluation. Regards, Marcjan @ Umencho, yes that's the shorter one But believe it or not there are still plc's without X-or instruction Attachmenttoggle-tia.pdf (2950 Downloads) |
12/9/2011 1:59 PM | |
Thank you, yet better. |
12/9/2011 5:21 PM | |
Joined: 7/7/2010 Last visit: 12/9/2023 Posts: 13994 Rating:
How does one code this solution in TIA Portal without SCL? |
science guy |
12/10/2011 2:31 PM | |
<OFFTOPIC> Just on target! BTW, do you think that is need to think about that, because around Christmas we expect released of SP2 of TIA v11 coming with SCL. Best regards, Hristo Mihalev |
10/20/2017 2:03 PM |
Posts: 1 Rating:
My solution is very easy :-) try it |
