12/3/2009 11:03 PM | |
Joined: 3/25/2008 Last visit: 1/28/2022 Posts: 232 Rating:
Hi Joan. It's been a lot of time since i did work with similar technologies the last time; i have to say i'm not a expert in this field, i just want to share my experience with you. First to all the modules i was working on where WF-723A, so we have a diference. So if the dip switches are now configured in the same way than the old card; you just have to try to download the whole program to the PLC but have in mind that the WF card must be alredy inserted. This operation should be made with the PLC in Stop mode. I'm sorry that's the only trick i know; but also i recomend to check this manuals WF Manuals Good luck |
Keep working! |
12/4/2009 10:17 AM | |
Posts: 4 Rating:
Many thanks! We will consider your suggestion. It's quite easy to check.. Anyway, I want to write down the results once we find the right way. Thanks again! |
