10/17/2014 9:48 AM | |
Joined: 1/5/2011 Last visit: 1/27/2023 Posts: 810 Rating:
Dear Bahman, I'm not 100% sure what you mean, but I think you are reffering to "dynamic text lists", maybe following link is useful to you: FAQ: How do you create dynamic text lists in WinCC (TIA Portal)? If you're trying to identify an entry from a text list,following link might be useful: https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=63973877515&TopicId=56857406603 Is this of any help to you? Kind regards, Jens |
Keep it simple and on-topic. |
10/22/2014 3:45 PM | |
Dear Bahman, thanks for elaborating, you can use tag multiplexing to achieve the result you desire, take a look at: FAQ: How does tag multiplexing work? It is a winCC flexible example, but the same method still applies in TiA portal. Hope this helps. Kind regards, Jens |
10/23/2014 2:44 PM | |
Posts: 5 Rating:
Thank you Jens, You give me the solution. I can use it in my project. Best wishes Bahman |
