4/21/2021 3:25 PM | |
Hello perhaps you can work with the Kalendar out of the Toolbox: https://support.industry.siemens.com/cs/de/en/view/106226404 Bye Murof |
4/21/2021 6:08 PM | |
Joined: 2/3/2017 Last visit: 4/4/2025 Posts: 2 Rating:
Hello perhaps you can work with the Kalendar out of the Toolbox: https://support.industry.siemens.com/cs/de/en/view/106226404 Bye Murof Hello Mr.Murof, I have gone through this toolbox document and found it generating calender overview with the current month and the following month based on the current date. Is there any other solution which I can try. |
