7/26/2010 6:12 PM | |
Joined: 11/15/2009 Last visit: 3/13/2023 Posts: 375 Rating:
Dear Ashish, For reduce the size of the current transaction file (*.ldf) can you use on your ES or OS “Prgrams\Microsoft SQL Server2005\SQL Server Management Studio” with “Tasks\Shrink”for more infohttp://msdn.microsoft.com/en-us/library/ms190757.aspx Regards |
3/19/2015 9:31 AM | |
Posts: 567 Rating:
Hi E_L_O,
The default setting is simple. You can find more information under FAQ "How can you reduce the size of the transaction file (*.LDF) of the database of a WinCC project?" |
3/20/2015 9:56 AM | |
Posts: 567 Rating:
Hi, did start the WinCC runtime on the ES? If yes you also backup the tag and alarm logging data. If you don't need the runtime data you can reset the tag and alarm logging archives. How you can reset the archives is described under the following link:
11/3/2017 10:41 AM | |
Joined: 6/19/2017 Last visit: 3/31/2023 Posts: 6704 Rating:
New question published by AutoGen_88105 is split to a separate thread with the subject Event list is empty after WinCC was running. Best regards |
