8/5/2021 7:38 AM | |
Joined: 4/28/2015 Last visit: 8/12/2022 Posts: 2905 Rating:
Hi, you can use the Service Stick to change the root password. Either the menu pops up immediately (of you set "enabled" in the last configuration step) or you login as user and call sudo mel-setup (if user has sudo rights) With the UART cable you can interrup the boot and choose a boot-device --> boot from SD or USB. All this is described in this manual. Best regards! |
