3/13/2017 9:20 PM | |
Posts: 10 Rating:
I need to send data block between 2 same cpu 412-2ek06-0ab0. This cpu has its own cp. I tried sfb14-15 but it doesnt work. Please help. |
3/14/2017 7:17 AM | |
hi, for SFB14/15 you need to establish a S7-connection. over this connection you can access the other CPU with PUT/GET. Sample program: S7 communication with the blocks SFB14 ("GET") and SFB15 ("PUT") with S7-400 for more help on this topic we need more information about what you are doing. hope this helps, regards |
FCK WAR! |
3/14/2017 11:33 AM | |
Posts: 1368 Rating:
Hello, do you know this manual? https://support.industry.siemens.com/cs/ww/de/view/20982954 In this compendium you find all possibilities for CPU-CPU Communication! Another question: The CPU 412-2 supports PROFINET. So why you do not establish a IO-Controller <=> I-Device connection or use simple the open communication blocks? Greetings, |
