12/22/2010 11:56 AM | |
Joined: 6/7/2010 Last visit: 7/9/2024 Posts: 571 Rating:
Hello Deep, Find the attachement for your reference & check the below mentioned points, 1] Same Badurate should be selected in CNC & Laptop. 2] Press connect ON softkey in CNC if you are going to communicate PLC. 3] Cable connection RS232. 4] COM 1 is to selected in CNC screen setting & Cable should to connected in COM1. Regards, Muthamizh Attachment802D.pdf (1159 Downloads) |
Regards, |
