11/5/2022 6:04 PM | |
Joined: 1/20/2017 Last visit: 9/24/2024 Posts: 7 Rating:
Hello.Please tell me how to set the default ruler on the trend at the beginning of the trend so that the values are immediately displayed. TIA V17. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/07/2022 06:23:10New subject after splitting Last edited by: kaa007 at: 11/08/2022 17:07:29 |
11/9/2022 8:59 AM | |
Please answer, is it possible to do this or not? In TIA V17. |
11/11/2022 1:33 PM | |
I am using TIA V17 professional |
11/18/2022 10:10 AM | |
Hello kaa007 I haven´t found a solution yet in WinCC Prof... I have found an old FAQ https://support.industry.siemens.com/cs/de/en/view/22287233 Its the same in WinCC Prof as in WinCC V7, but I am not sure if there has changed something since this information... Bye Murof |
11/23/2022 6:42 AM | |
Thank you.Too bad there is no solution. |
