7/11/2013 8:13 PM | |
Posts: 116 Rating:
Hi, what is the exaxt type of your camera system and which interfaces does it have? Regards Jerry |
7/12/2013 3:17 PM | |
Posts: 344 Rating:
It appears that Simatic VS 723-2 is a discontinued product. According to the manual VS72x vision camera supports Profibus DP, Profinet and TCP/IP communications. Simotion supports all those protocols as well. To get them to talk together, Simotion needs to know (in the program) what data does the camera send and receive. The description is in the SIMATIC VS72x Communication manual. For some reason this document is marked as internal (export regulations?) so you will need to ask your local Siemens rep to get it for you. |
