11/15/2016 2:43 PM | |
hi, have a look to the CPU-CPU-Communication manual As you see on page 40 communication is possible with the S7-400 as slave or with the S7-1500 and CP1542-5 as slave. How should it be done? regards, |
FCK WAR! |
11/15/2016 3:22 PM | |
Posts: 35 Rating:
Thanks. The 400 cpu needs to be master and should not be disturbed if the 1500 cpu stops. |
11/15/2016 3:42 PM | |
hi, Therefore you need the CP1542-5. here you can find the Profibus GSD-files With this files you can project the CP1542-5 as Profibus-node in Step7 5.5 hope this helps, regards, |
