7/29/2008 11:26 AM | |
Posts: 328 Rating: (29)
Dear Sir Are your upper and lower turrets in seperate channels? If they are in the same channel it will be difficult to acheive what you require as all the axes are treated as interpolation axes, as a result, if programmed in the same line they will reach there final position at the same time. If the are declared in seperate channels then it should be possible to re-engineer your part programs but without more specific information, It will be difficult to advise further. Please see the attached link to programming information https://www.automation.siemens.com/doconweb/content.asp?item=1959&cd=sinumerik_simodrive_04_2008_e&scope=all Regards SteveJ |
