5/5/2010 11:09 AM | |
Posts: 6 Rating:
Dear Nit thank you for kindly attention. can you help me about this.it seen you have god experience about this problem we have servo motor(not for siemense)and i am sure the encoder of this motor have problem the encoder is from stegman and have 2 parts.code disk and sensor block i instal the encoder on motor and check sin wave with osiloscop.but for physically adjusting we must syncronize zero crossing of encoder actual value and zero crossing of emf signal of motor.How we can do this Splitted from linear & Encoder change.
5/6/2010 11:43 AM | |
Posts: 6 Rating:
i will be gratful if give me information about synchronization ofsiemense becuse it may be help me best regard |
5/6/2010 4:00 PM | |
Joined: 10/17/2007 Last visit: 3/25/2025 Posts: 4253 Rating:
==================== hi, Nit is right u cannot deactive motor encoder. ref the link below to try syncronization.or check attachment on page 140. good luck. /tf/WW/en/Posts/43152#top AttachmentIADC.zip (157 Downloads) |
If you like my comments please |
5/11/2010 8:03 AM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating:
Thread closed, because question is already discussed in the following thread change ABS Encoder and syncronize encoder with motor. Best regards O_Moderator |
