5/9/2020 12:45 AM | |
Joined: 9/12/2019 Last visit: 2/5/2023 Posts: 1 Rating:
Hello, Please how do you toggle a push button at the ''EVENTS'' SET and RESET in Wincc Unified? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/11/2020 06:45:46New subject after splitting |
5/12/2020 1:50 AM | |
Joined: 7/25/2017 Last visit: 2/8/2023 Posts: 228 Rating:
Hello, if you mean you want a BOOL tag to toggle FALSE/TRUE when clicked, you can use the InvertBitInTag function (select bit number 0). See attached. BUT! The value of the tags must be current and valid, which means the quality code must correspond to Good (cascade). See this entry: https://support.industry.siemens.com/cs/mdm/109773780?c=122539274507&lc=en-US |
