10/3/2009 7:44 AM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Hello, Connect PG with panel, using TTY cable. When the panel is switch on, you'll see there menu occured and in this menu select online with COMTEXT.System OPMode - ONLINE. Now trough COMTEXT menu you could upload panel program. Use manual for more details - OP5 Operator Panel . Don't use combination of keys (ESC + Right Arrow + Down Arrow) to put OP into download mode.
You can do this only if you want to transfer new program to the panel, without care about old one. Or if you have new panel. Hope this will helps. Best regrads, Hristo Mihalev |
10/3/2009 11:28 AM | |
Posts: 8 Rating:
Thanks UMENCHO for your answer. Can you share me COMTEXT software? Thanks! |
5/14/2012 6:25 AM | |
Joined: 5/4/2012 Last visit: 4/10/2023 Posts: 11 Rating:
Dear UMENCHO, Thanks God, that i can found the way to upload the OP5 program. Thanks for your information. |
