4/17/2018 1:56 PM | |
Joined: 4/28/2015 Last visit: 1/25/2023 Posts: 385 Rating:
Hello, you have to emulate encoder signal with using analog signal. For this, you could use the function block you find in the following application example: https://support.industry.siemens.com/cs/ww/en/view/109741575 Generate technology object "PositioningAxis" in S7-1200, bound TO to data block (DB) and emulate encoder singal with function block in OB "MC-PreServo". If you want to manipulate output of technology object too, you could also use OB "MC-PostServo" for doing this... |
10/10/2021 5:18 PM | |
Joined: 7/30/2010 Last visit: 8/27/2022 Posts: 1 Rating:
Hello How did you change fb for s71200?
