4/17/2018 7:23 PM | |
Posts: 2 Rating:
Hello guys, Do you know how to use CPU 315F 2DN/DP as a Profinet Master? Thanks in advance ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 4/18/2018 12:08:30 PMNew subject after splitting |
4/20/2018 9:52 AM | |
Posts: 1368 Rating:
Hello, as soon you connect a PROFINET network to a PLC, the PLC is controller. You must not do anything for mode "PN controller". The IO-Devices on the PROFINET network you can assign to this Controller. Only if you want the PLC to work in mode "IO-Device", you have to change the operating mode in HW-Config. |
