8/1/2017 8:35 AM | |
Joined: 5/12/2006 Last visit: 10/15/2024 Posts: 22414 Rating: (3017)
Hello, a application example you can found here: https://support.industry.siemens.com/cs/ww/en/view/98961635 Yes you marked the correct address in your picture.
Christoph |
8/1/2017 8:58 AM | |
Posts: 48 Rating: (0) |
Hello I download example file from your link but not work because these file is version 12(TIA12) my TIA is version 14. How I can do it? Thank you very much.. |
8/1/2017 9:01 AM | |
install TIA V13 SP1, convert the V14 project to V13 Sp1 then convert it to V14 |
8/1/2017 10:08 AM | |
Hello, a pdf is on the page i linked, in this you find the description with pictures for the application example.
Christoph AttachmentS7_1200_TIA_Portal_with_S120_EPos_Comm_V1.6_V13_SP1_V14.zap14.zip (122 Downloads) |
