8/9/2015 11:41 AM | |
Joined: 5/12/2006 Last visit: 10/9/2024 Posts: 22405 Rating: (3017)
Hello,
here you can find a applicatin example with description for using S7-1x00 with telegem 111 with sinamics S. https://support.industry.siemens.com/cs/ww/en/view/98961635 The Technology Objects can't work/used with telegram 111, for this you must use Telegram 1,2 or 3. Regards Christoph |
8/10/2015 3:22 PM | |
Hello, check the configuration of the drive. Check r46 if any enable signal is missing. check the settings for the command value in the S110. have you a wiring overview of you used devices? here you find 2 examples for s7-1200 with Puls/direction interface: https://support.industry.siemens.com/cs/ww/en/view/77467940 https://support.industry.siemens.com/cs/ww/en/view/38391227
Regards Christoph |
