2/9/2021 6:55 AM | |
Joined: 12/2/2020 Last visit: 11/30/2022 Posts: 38 Rating:
Hello, I have too an application with G120 inverter and analog linear encoder, i'm trying to do positioning axis but need another type encoder and I cant use it, so I'm using speed axis. Do you have an idea to use position axis with analog linear encoder? Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/09/2021 09:04:15New subject after splitting |
2/9/2021 12:12 PM | |
Joined: 10/11/2006 Last visit: 1/27/2023 Posts: 5404 Rating:
Hello, there is an example, how to configure analog sensor with TO. Using the MC-PreServo and MC-PostServo organization blocks https://support.industry.siemens.com/cs/at/en/view/109741575 |
With best regards, |
2/12/2021 9:41 AM | |
Hello, 16#8001 A technology alarm (technology object error) occurred while processing the Motion Control instruction. In the technology data block, an error message is output at the "ErrorDetail.Number" tag. You can find a list of the technology alarms and alarm reactions in the "Technology alarms (Page 140)" appendix A.2 Error ID for Motion Control instructions (S7-1500, S7-1500T) https://support.industry.siemens.com/cs/ww/en/view/109766459 |
