1/24/2013 12:48 PM | |
Joined: 8/10/2005 Last visit: 2/7/2022 Posts: 3609 Rating:
Import of a Technical Question of the User douglasgimenez
1/24/2013 1:06 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, There is a FAQ that explains a bit more i think: How can you avoid overwriting the flags that are allocated for system and clock memory bits in the user program? Once sm byte is selected in CPU properties, you can use them as any other bit. First scan you can use to initialize things at startup. Pulse you can use to blink a light. Regards, Marcjan |
Problem solved? |
