4/23/2012 5:59 AM | |
Posts: 1064 Rating:
Wincc flex uses vb or vbs not c++ Youyu have to reright your scripts in vb to make them work |
4/23/2012 6:07 AM | |
Posts: 3 Rating:
Hi Steve, can you give me and example VB script,because i not really familiar with programming . Your help highly appriciated. Daniel
4/23/2012 6:34 AM | |
Posts: 1064 Rating:
I will try and write something tomorrow as i am at work right now am having problems sorry |
4/24/2012 12:02 PM | |
Posts: 3037 Rating:
Hello You can use to flashing of objects theaninmation "Appearance" in WinCC flexible. See the screenshot. Then you can set the different value of the animationin the script. Allocation of tag in a script in WinCC flexible: SmartTags("Variable_1")= 100 Which VBS information and programming aids are there in WinCC flexible? Tweety |
