3/31/2008 6:00 PM | |
Posts: 33 Rating:
thanks I guess I will use profibus. |
4/1/2008 9:15 AM | |
Joined: 4/24/2006 Last visit: 2/7/2025 Posts: 8839 Rating:
Hi Sydney, You are right. http://support.automation.siemens.com/WW/view/en/15115523 If Profibus transmission rate is 1,5 MB/s: max segment length is 200 mtr. MPI cable length: This depends on the used MPI interface. When you use non-isolated MPI interface the max length is 50 mtr. And when you use isolated MPI interface you can go to a 1000 mtr. Please have a look at the following link, where you can find products with isolated interface: http://support.automation.siemens.com/WW/view/en/12907719 Best regards, Wizard |
