12/9/2022 8:54 PM | |
Joined: 3/11/2012 Last visit: 1/17/2023 Posts: 18 Rating:
Same problem here. Running bat file did not help. Then i looked at the application pools and started WebRHPool. None of this fixed it. Did also try the Unified Configuration. It freezes up at the Reporting section. Reporting is not running for some reason. Then i tried the certficate manager. Did make a certificate but no idea how to install it. I can't select it in Unified Configuration. In V17 there was a choice to install from "Certficate Autority" on start page. That appears to be gone in V18. However my initial fault with HTTP Error 503 has now been replaced with a certificate issue. Cant access runtime since i don' have a certificate. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/12/2022 04:58:04New subject after splitting |
12/11/2022 5:24 PM | |
Joined: 1/10/2020 Last visit: 1/21/2023 Posts: 24 Rating:
you assign the certificates to the https protocol of the localhost from iis like the screenshots that I am attaching, [snip] AttachmentScreenshots.zip (10 Downloads) |
Last edited by: Jen_Moderator at: 12/12/2022 05:06:08Removed links and added files as zip file. Last edited by: domenico2020 at: 12/12/2022 07:59:14 |
