3/13/2006 4:19 PM | |
Posts: 3149 Rating: (171)
Hi oserit, well, normally in V4 your database is not allowed to be bigger than 2GB. Elsewise it's not for sure, that systemstability is guaranteed. For V5 I´ve founde a little FAQ for exchanging the the RT-DB http://support.automation.siemens.com/WW/view/en/8795809 You should use the option "storage" for your storing your taglogging data. good luck nemo |
