2/2/2009 9:14 PM | |
Joined: 7/16/2006 Last visit: 1/2/2024 Posts: 1502 Rating:
Hi I have check: CP343-1 Lean V1.13 6GK7 343-1CX00-0XE0 Firmware 1.0 works with Step7 V5.2 CP343-1 Lean V1.27 6GK7 343-1CX00-0XE0 Firmware 2.0 works with Step7 V5.4 What is you Firmware from CP343-1 ? Install SP1 for V5.2 http://support.automation.siemens.com/WW/view/en/16540057 Then install HF3 for V5.2SP1 http://support.automation.siemens.com/WW/view/en/17545812 |
Karl |
2/6/2009 9:27 PM | |
Hi Complete Path "Industrial Ethernet" is not possible. See my *.DOC Do you have Install the Packages for "Indusrial Ethernet" AttachmentInfo.zip (210 Downloads) |
Karl |
2/7/2009 8:08 PM | |
Hi I'm not sure. You can try follow download. I hope that help you. http://support.automation.siemens.com/WW/view/en/19027119 |
Karl |
2/8/2009 3:25 PM | |
Posts: 14 Rating:
Thanks Karl, I intalled it and everythink is OK !!!!! Paja |
