8/25/2010 5:26 PM | |
Posts: 5822 Rating:
Hello, I am not sure, but with STEP7, I guess this is what you have as SIMATIC Software you will not communicate with the CP 5512. For this CP you require the Software SIMATIC NET SOFTNET S7 for PROFIBUS or SOFTNET DP Master or Slave. The mayor problem may be to run this all on the by you used OS, Windows 2000 is not supported by SIMATIC NET for quite a long time already. For the communication itself you would be able to use OPC functions this may ease your programming a lot, I guess. The only point I see as said is the question about the usability of the driver with your OS. Check this FAQ for more details: Which SIMATIC NET CD is released for which Microsoft Windows operating system? Best regards J_Bell |
