2/18/2006 12:05 PM | |
Posts: 25 Rating:
when i use the s7-symbol in the wincc,i can't delete it and modify it in the TAG managment ,how to do?????? |
2/19/2006 8:48 AM | |
Posts: 3149 Rating:
Hi Blondy, you could try to modify your tags by script: /tf/WW/en/Posts/2106 nemo |
2/20/2006 2:12 PM | |
Posts: 25 Rating:
thanks! |
3/1/2023 2:51 PM | |
Joined: 8/3/2009 Last visit: 11/30/2023 Posts: 11798 Rating:
Hello the user Salma has visited the Forum last in 2007... I would not think that you get an answer to this old topic. In the newer Versions you can check this FAQ: https://support.industry.siemens.com/cs/de/en/view/109780478 Bye Murof |
