9/18/2008 4:11 PM | |
Posts: 487 Rating: (45) |
To use be able to browse/connect to external OPC server, you should make sure your DCOM settings are correct. www.opcfoundation.org > Downloads > White Papers > Using OPC via DCOM with Windows XP Service Pack 2. Check the links below http://support.automation.siemens.com/WW/view/en/12069091 http://support.automation.siemens.com/WW/view/en/15049230 |
2/27/2009 11:53 AM | |
Posts: 139 Rating: (1) |
JMJ: May be you can explain little bit more what you are trying to do here. Are you trying to get the data from another WinCC server? One more example. If You want to connect PLCSIM on different computers, you may need OPC connection between 2 WinCC. For more details see here: /tf/WW/en/Posts/22779 |
Last edited by: SpKV at: 2/27/2009 11:55 AMLast edited by: SpKV at: 2/27/2009 11:54 AM |
7/2/2015 1:44 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating: (122) |
