4/15/2009 10:23 PM | |
Posts: 2661 Rating: (279)
Hi Lukasz, After you uninstall SQL Server 2000, you need to clear certain entries from the registry. See point 4 in the following FAQ: How should you proceed when installation of the Microsoft SQL Servers fails? Alsodouble-check thatthe following FAQ is not applicable in your case: Why can't you install the SQL server from WinCC V6.2 or WinCC V6.2 SP2 after installing WinCC flexible 2008? Regards |
