4/11/2009 1:46 PM | |
Posts: 557 Rating:
hi I think software installation is having a problem.Deinstall & again intall...... if you are using a wincc then check the computer name with your wincc backup...... are you able to go in runtime....if yes then softwareinstallation is have some problem. find the link hope this will help you.... http://support.automation.siemens.com/WW/view/en/22089969 regards |
