10/13/2009 1:37 PM | |
Posts: 100 Rating:
Thanks H-H. [schnipp schnapp] |
Last edited by: O_Moderator at: 10/14/2009 8:47 AMother question of this post is published in the thread /tf/WW/en/Posts/35570 |
10/14/2009 2:18 PM | |
Joined: 8/10/2009 Last visit: 7/10/2022 Posts: 29 Rating:
Hello Sundar, I am sorry to tell you that Siemens MMC cards have a special format. Only a PG or a portable MMC reader can read these cards directly. It appears that someone has inserted the 'bad' MMC into a PC and allowed the PC to format it (put a FAT table on it). The card is no longer usable in SIMATIC. I do not know for sure if Siemens offers a reformatting service or not, but it would not hurt to ask. Wish I had better news. |
10/16/2009 7:24 AM | |
Posts: 2348 Rating:
If card is formatted in PC it can't be used in PLC - i'm totally agree with weddra. But you can find empty images of Simatic MMCs and put that image to foramtted card via card-reader. Then it should work. |
10/16/2009 9:25 AM | |
Joined: 5/28/2008 Last visit: 3/24/2025 Posts: 4520 Rating:
Dear sundar, The MMCs of the S7-300 may be read or written only by the following devices outside the CPU:
Warning: |
Ayman Elotaify |
10/27/2009 5:29 AM | |
Posts: 100 Rating:
Thanks to all. Now i have only one (formated) memory card . could anybody send simatic images and files of the simatic MMC. is it possible to send that file to MMC through mmcport(not using card reader). If i should use card reader means should i use normal card reader or simatic card reader.
10/27/2009 11:29 AM | |
Dear sundar, As I have told you in my previous post, It's recommended to order a new MMC from Siemens. If you get the image from any where, I am sure that Siemens does not grantee that MMC. Please check the following FAQ: Why is the MMC no longer recognized by SIMATIC devices after it has been formatted in a third-party device? Regards, |
Ayman Elotaify |
To explore the new Forum, you can follow the textbox in the right column, which will lead you to the corresponding page in the new Forum. Alternatively, you can start from the main page by following this link:
https://sieportal.siemens.com/en-ww/support/forum
In the coming days, we will update the configuration step by step, so that you are directed to the new Forum by default. The “classic Forum” will remain available for all known functionalities alongside the new one.
We are thrilled to finally share the future of our Forum with you. Thank you for your commitment!
Kind regards,
the Forum Support Team
