11/30/2010 2:59 PM | |
Posts: 2964 Rating: (484) |
Hello.... This look a 810D controller if i guess correctly..... Have you tried to ping the IP address and check the communication is happening on the both control CNC side as well as on LAPTOP / PCPG If you have activated the fire wall you need to disable it.... I am attaching the steps and example for connecting in to CNC machine with 810D Hope fully this will help you check it out.... Regards, Ekalavya AttachmentETHERNET CONFIGURATION.pdf (108 Downloads) |
