4/5/2017 2:15 PM | |
Hello OpisOm Which client do you use? Smart client app, or Smart client Application or SmartclientView in another Panel or Internet Explorer with Java Plugin? Which Version of TIA Portal do you use? If you have a TP700 Comfort then you could use 3 parallel Connections of smart clients Or do you use a KTP700 Basic 2nd Generation?? If the Panel shows a curious behaviour then you sould do a Reset to factory settings and configurate and load again: https://support.industry.siemens.com/cs/ww/en/view/19701610 Bye Murof |
4/18/2017 5:05 PM | |
Posts: 648 Rating:
Dear Opsi, can you take an screenshot or a Picture of your sm@rtServer settings in your project and at the panel? I would say, you have set a time out. With best regards rh1990 |
