8/15/2012 2:20 PM | |
Joined: 4/24/2006 Last visit: 5/16/2022 Posts: 8430 Rating:
Hello Denza, Perhaps you can use a Comfort Panel: Delivery Release: SIMATIC HMI Comfort Panels Delivery Release for SIMATIC HMI Comfort Panels You will have to use software WinCC Comfort V11. Please have a look at the starter packages. Best regards, Wizard |
8/15/2012 2:25 PM | |
Joined: 9/27/2006 Last visit: 5/16/2022 Posts: 11630 Rating:
Hello Denza; Have a look through the Siemens HMI brochure: https://www.automation.siemens.com/salesmaterial-as/brochure/en/brochure_panels_en.pdf?HTTPS=REDIR The Technical Specifications sectionshould bequite useful in your selection of HMI panels. Depending on the number of keys you require you can either go up to a Comfort Panel (the KP 900 Comfort has 26 keys, and a 9" screen), or you can select whatever panel you choose and add a 8- or32-keypad that will be a standalone slave to the PLC over Profinet. These are configured using Step 7 Basic V. 11. Hope this ehlps, Daniel Chartier |
